Kraut_n_Rice
Site Sponsor
- May 9, 2021
- 3,545
- 2,805
Halve the voltage to halve the motor speed (and noise) at lower tempsNot following ya.
Ah. Spal makes some really nice brushless PMW fans that use a very small sender. The rest is integrated into the motor. Simple wiring, and senders with different response (temperature) rates. Think the one we use is on 100% at 140f.Halve the voltage to halve the motor speed (and noise) at lower temps
Nice! Who'd you find it through? Everything I found is euro...Ah. Spal makes some really nice brushless PMW fans that use a very small sender. The rest is integrated into the motor. Simple wiring, and senders with different response (temperature) rates. Think the one we use is on 100% at 140f.
https://www.spalautomotive.it/brushless
Because SPAL doesn't gimmick their testing to get a high CFM number. Compare:Ok, curious about why everyone goes with SPAL fans. The CFM on SPAL fans are not that impressive. Is there another reason they are widely used? I went with Perma Cool Fans on my intercooler and they work great at almost triple the CFM of the same size SPAL.
Found a CFM chart for these fans:We buy the fan through our hydraulics supplier. I found all the electronics online. Kartek seems to carry it though.
These guys offer kits. Might be able to piece what you want together tho. https://wizardcooling.com/diy-kits/diy-brushless-fan-kits/
For a fan of the same diameter to TRULY move 3x the air it would very power hungry and loud.Ok, curious about why everyone goes with SPAL fans. The CFM on SPAL fans are not that impressive. Is there another reason they are widely used? I went with Perma Cool Fans on my intercooler and they work great at almost triple the CFM of the same size SPAL.
There was a tread a few weeks ago about fans. I think I posted about the 30103202 in it. I have two on my TBSS. Those fans are no joke.Because SPAL doesn't gimmick their testing to get a high CFM number. Compare:
https://www.holley.com/products/cooling/fans/parts/30103202
https://derale.com/product-footer/electric-fans/universal-electric-fans/h-o-extreme/12-high-output-rad-pusher-fan-2014-08-14-718-detail
Ah yes, good thread.There was a tread a few weeks ago about fans. I think I posted about the 30103202 in it. I have two on my TBSS. Those fans are no joke.
ETA. thread link
My 9" intercooler fans are just as loud as my 16" radiator fans and seem to have the same pressure from the fans (unscientific hand test, lol)For a fan of the same diameter to TRULY move 3x the air it would very power hungry and loud.
Do you have links to compare?
You answered this yourself. If a 9" fan appears to be moving the same amount of air as a 16", one is clearly "better" than the other. Noise could just be poor blade design.My 9" intercooler fans are just as loud as my 16" radiator fans and seem to have the same pressure from the fans (unscientific hand test, lol)
To the hand the velocity of the air seems the close (SPALs on the radiator and Perma on the intercooler). It would be interesting to see a comparison between them. I need to build a shroud on my intercooler to get better flow over the whole thing, and I want to go to 9" fans from my 8", so maybe i'll try the SPALs and see how they do.You answered this yourself. If a 9" fan appears to be moving the same amount of air as a 16", one is clearly "better" than the other. Noise could just be poor blade design.
That test is not very good, apples to apples. The Maradyn is rated considerably higher in CFM (25%~) and amperage (50%~) than the Spal. The amperage being the big one. Much larger motor.To the hand the velocity of the air seems the close (SPALs on the radiator and Perma on the intercooler). It would be interesting to see a comparison between them. I need to build a shroud on my intercooler to get better flow over the whole thing, and I want to go to 9" fans from my 8", so maybe i'll try the SPALs and see how they do.
I did find this: Where the SPAL did better off the radiator but the Maradyn did better on the radiator.
