Cookie
- 2,460
^^^ This would work as well. I thought you said you already have a battery in the trailer? This is a very easy project, you have this one for sure
I already have a car battery in my trailer...not hooked up to anything though. It looks cool. :lmao:^^^ This would work as well. I thought you said you already have a battery in the trailer? This is a very easy project, you have this one for sure![]()
exactly!Only asked how to control 2 LED lights off a switch to his battery...
...ended up with
:lmao:
OK, now I see what you're trying to do. Several people have already given good advice on how to hook them up.I already have a car battery in my trailer...not hooked up to anything though. It looks cool. :lmao:
So, when I camp, the battery is used to run my tv/dvd combo. I hook up my inverter to the batter then I watch TV. When done I simply disconnect the inverter.
What I am wanting to do is run my LED lights in the trailer off the battery as well without making it too complicated.
That is why I thought of that 7 way male end...drill, mount, hook up the correct wiring to the battery and then I have use of my lights and usb charging port.
That's it.
My microwave and coffee maker run off my generator, so there is no need for massive power from my battery.
that's the plan.I thought I wanted an enclosed trailer! Now, not so sure
Ok, Dbart. Here's what I would do... I would run about a 10g red wire from the car battery positive, tapped in to the 12v hot wire on the trailer plug. Then, just ground the battery to the trailer. You will have 12v power to the trailer as if it was hooked up to the truck when disconnected. You will still be able to run your inverter and have the battery charge when hooked up to the truck.
Fancythat's the plan.
I got the male end of the 7-way...Just need to drill and mount it to the front of the trailer, then connect the right wire to the positive plus a fuse in between, then a ground.
Sorry if my gauge of wire offends your expertise. I just see what's hanging on the rack at O'ReillyFuses are for people that run the correct gauge of wire....
If you run the wrong gauge wire, the wire becomes the fuse...Fuses are for people that run the correct gauge of wire....
Depends on which way you go... LOLIf you run the wrong gauge wire, the wire becomes the fuse...
well that is one way to do it.Ok some fun stuff today. Installed new tall cabinet and got the main wiring harness in.
I still have to clean up the inside. The screws are too long and there's a gap I need to cover up. But the main part is in as far as the wiring.
I have long arms. :lmao:Why the 7 way as an entry? Must have been a bitch to tighten the nuts. Try some t nuts
