TheSPAINishLover
- 1,357
You post the most useful information on this forum! Anytime you post, I find myself compelled to read every word of your posts…something I don’t do. I also typically bookmark them.When it comes to D'max you either want the '06-early '07 ("cat-eye" body style, not the new body '07.5) or you want a '11+. The '06-early '07 are the LBZ with a 6-speed Allison, prior to '06 it was a '05 speed which was a little weaker in some areas, and various different versions of the D'max (LB7, LLY). People love the LBZ because it got a power bump, has a cat but no DPF, and like I said got the 6-speed. '07.5-10 were the LMM which *would* be another great Duramax, but it got a DPF and I'm not a fan of the regen strategy (injecting fuel on the exhaust stroke). '11+ is the LML, which saw an upgrade to the 6-speed Allison, a completely new frame (even though the cab and bed look nearly identical to the LMM generation, inside and out), bigger brakes, beefier suspension/steering components, etc. The downside of a LML is it did add DEF, but at least it has a sane regen strategy (9th injector in the downpipe, low pressure). The L5P came around in '17 and got a good power bump, but those are going to be spendy trucks.
-TJ
You’re fasho invited to the carne asada here in Knoxville (and FL when my place is finished) if you ever find yourself out this way. :cheers:
