matt86m
- May 6, 2021
- 1,156
- 1,341
Just picked up my 2013 Chevy 3500 from the shop. $780!!! DEF sucks! Stick with gas if you don't need to haul heavy.
i just did a fan clutch, rear shroud, thermostat and temp sender and doing it myself in my 05 SD was over $800Just picked up my 2013 Chevy 3500 from the shop. $780!!! DEF sucks! Stick with gas if you don't need to haul heavy.
I have a 3.5 in my '19 F150. Commuting to work I average 24mpg. We did a round trip from Norco to Vegas to Havasu and back home Saturday and I was @ 23 with an average speed of 80mph.Gas, 1/2 ton. Ram or Ford right now. If just your usual flatbed with quads, tent and a cooler: 2.7 Ford ecoboost has plenty of power, especially with the 10 speed. Chevy cylinder deactivation AND DI is going to be problems eventually, either from gummed up intake ports or lost cylinder deactivation lifters. Ford added port injection to solve the gumming, Ram 1500 is still port injection and their cylinder deactivation is a little more robust. Hemi has exhaust manifold issues, but at least that doesn’t take the motor with it.
Ford “ecoboost” is eco or boost though. Drive it like a grandpa, good mpg. Use the turbos, terrible mpg.
Nice!I have a 3.5 in my '19 F150. Commuting to work I average 24mpg. We did a round trip from Norco to Vegas to Havasu and back home Saturday and I was @ 23 with an average speed of 80mph.
Towing does suck for sure. Doesn't matter if it's the boat or enclosed, it drops to 12. I may as well use the diesel at that pointNice!
And by grandpa, I mean accelerating. Cruising on the freeway, they're great. Towing or leadfooting it... Not so much :biggrin:
Uses 87, has early 2000s diesel torque, but so quiet my buddy used to try to start his when it was running all the time. :biggrin:Towing does suck for sure. Doesn't matter if it's the boat or enclosed, it drops to 12. I may as well use the diesel at that point
I just jumped into a diesel for the first time. If I wasn't towing a 40ft pig I would still be gas. I towed it for ~3 years with a 02 GMC 8.1L gasser but the 5mpg towing on a 26gal tank was killing me, not to mention the extended cab vs crew cab and the boys don't fit in the back anymore, taking two cars anytime we drove it. It was time for a new truck either way. We still have the GMC, Evan is driving it until I get the Wrangler back on the road. Eric is now driving my 2010 Dodge Ram 1500 hemi with 210k miles on it... were it not for the big ass toy hauler I'd have another Dodge 1500 but 4wd this time, and consider that to be my last truck purchase ever.My wife and I are throwing around the idea of a new/er truck.
Currently, we have a 1500 that has been lovely. We are considering a larger, possibly diesel truck.
We do not have a specific need as far as heavy loads or trailers. Just the idea of buying a truck for longevity, strength and potential for hauling larger cargo.
As of now, we only haul a single axle open trailer for Glamis. ZERO plans for a toy hauler or larger unit with big vehicles. But would like the ability to pull a vehicle, trailer, equipment, if needed. Especially with a move out of California always in the works.
Please. Pro's / Con's of gas vs diesel. This could be my last truck purchase.
Only bummer about the 22 Tundra is they left a couple square inches on the front not dedicated to grille…FWIW, the 2022 Tundra is all new from the ground up. New twin turbo V6 with new 10 speed trans and coil spring rear suspension. The engine and trans have been used in other vehicles of course and all the SUVs have had coils for the last 30 years but I would steer clear of a first year vehicle from any maker, even Toyota. I don't think it would leave you stranded but small issues are bound to pop up.
The new Tundra in the hybrid would seem to be a good choice. Lots of hp and tq.FWIW, the 2022 Tundra is all new from the ground up. New twin turbo V6 with new 10 speed trans and coil spring rear suspension. The engine and trans have been used in other vehicles of course and all the SUVs have had coils for the last 30 years but I would steer clear of a first year vehicle from any maker, even Toyota. I don't think it would leave you stranded but small issues are bound to pop up.
It's 6.2 gas engine and 10 speed trans in the 2022s.Glad I came across this thread again as I might be changing my tune about Diesel.
There is a chance my truck is going bye bye and I'll explain in another thread if it actually happens.
That being said, I am seriously considering a new GMC AT4 2500 with the 6.6 Gas motor and 6spd trans.
My trailer loaded with my can am is probably 5500 at Most!
Do I need the diesel....do I even need a 2500 series truck...No!
But, I don't think I could go back to a 1500 series truck. Too soft and drives like a car...No thanks.
That being said, I think the gas version would do right well!
Doubt the mileage will compare. Towing I get 12-14. Freeway is 19-20's, around town is 14-16.
I love my truck and I love the power of the diesel and the torque...but the new ones have the 10 spd trans which says Allison but actually isn't an Allison trans. I'm hearing problems with them around the 30-35K mark. Apparently GM and Ford developed this trans with insight from Allison, so they put the name on the sides of their trucks.
Diesel fuel these days are changing and expensive as Eff. Also, Don't run the Bio-Diesel as told to my by GM Technician.
They mess up the injectors and fuel rails...since it is a fuel issue, it isn't covered under warranty! :kenk:
Def fluid, fuel filters, dual batteries, etc...it all adds up. Oil changes are pricey unless your dealer offers the 3 for the price of 1 deal.
I think I'm gonna go test drive a new one with the 6.6 gas and see what it's all about!
:dbart:
