Fireballsocal
- May 6, 2021
- 605
- 550
That turned out pretty good!
Too cold to start. Turn the heat up or feed down. You can always pull back a little as you weld and the heat starts to cause problems.What do those little splatter balls mean? Some welds have more than others. But i kept the settings the same. So it must be mistakes in technique? Its possible the splatter welds had more stick out. I was afraid to touch the tip of the welder to the metal. One video said you can weld the gun right to the metal.
