ROBERT L
Moderator
- May 2, 2021
- 5,058
- 3,778
Good luck buddy
I would say this is appropriate under the circumstances, if the new clutch worksthere has to be some reason they said the crank needed replaced you know @SandTrap inquiring minds want to know.request Can Am give you an extended warranty.
I didnt ask how it was installed all I know is they said they triple checked it and it was good as far as they could see. I did ask them when they said it would be Major work if this didnt fix it that why they wouldnt just send a New Longblock? The dealer said its 100 percent up too what BRP thinks is most cost effective. I said to the service manager again there is NO WAY you are pulling the engine apart to do a new crankshaft. He agreed that a totally NEW longblock would be faster and easier if it came to that but said again it up to BRP..Did the new Primary have to be pressed on or did it slip on? If two primaries just slip on & off, then I’d think it’s a crank issue. But if the new primary was tight going on, then maybe it was just a bad primary casting.
I hope it’s fixed for you and you see 1000’s of fun miles on your new toy.
But I’m still really bummed to hear how BRP handled this.
I would run your car around the dealer parking lot, if there is room or down the street by the dealer if possible. Then have them check the bolt in front of you.I am picking it up Tomorrow with New Primary clutch so we will see Fingers crossed it works
Yes it got a new washer and bolt and Bearing and seal and Primary and a New BeltI would run your car around the dealer parking lot, if there is room or down the street by the dealer if possible. Then have them check the bolt in front of you.
As stated make sure they put a new primary bolt in it. I hope they threw a new belt on your car a well.
