- Thread starter
- #401
onanysunday
- May 7, 2021
- 3,502
- 3,326
Patina on this is SBA.
You can buy a used Nissan Pathfinder 90° box. It is basically the same thing but doesn't have the 35° gimbal. I had spent hours reaching out to all kinds of people on Facebook trying to find one of those with under 100,000 miles. Almost impossible to find. Most of them have 150,000 plus miles on them.wow $800-$1500 for the VDOG https://www.flamingriver.com/vdog-variable-angle-gear
I need something like that for my build but that's out of the budget.... guess I better find the one you mentioned 10 pages back
Old post from earlier in the thread. I am still worried about the ratio though. Being too quickWith the factory Corvette rack one full turn of the steering wheel moves the rack 2.090 in. These photos show how far the steering turns at that amount. (On the car it will go further but on the truck I don't think I have the room anyway) The gear one super rack is 4 inches lock to lock. 1.5 turns lock to lock. So three quarters of a turn on the gear one rack versus one full turn on the stock steering to move it the same distance. I have to think that will be okay? Could the steering be too quick though? I could change the gear ratio in my chain drive setup if I wanted while building it. Those gears will get welded to the double d shaft so it will be hard to just change gears in that setup once I build it.
Well isn't that cool! Did not know these existed. Says you can speed up or slow the steering down. In my case it would need to slow it down. This would be simple to add later on. Would take brackets to mount and then add a couple more u-joints. Now I won't worry about it. Consensus in the shop is a little quicker steering for this truck will be fine. Just need to get used to it. :dude: Would like the see the inside of one of these and the gears.Have you tried to see if you could get a steering quickener installed backwards in between the column and rack?
https://www.summitracing.com/parts/hre-5225?seid=srese1&gclid=CjwKCAjw8symBhAqEiwAaTA__DV6ROJixMsUHaWhoxYuPbVWXD7HDMvGZnaes7grZ0o7ssebL9Ut8hoC9QIQAvD_BwE
