- Thread starter
- #321
onanysunday
- May 7, 2021
- 3,504
- 3,326
:laughl:Well it looks like you got the hard part done, should be easy sailing from here on out. Finished by Labor Day I would think.
Rad and intercooler will be fed by the grill up front. Yes separated from the cab completely and basically a duct made of panels to let the air through. This has been driving me crazy how to design it. I want it really clean in the back other than the turbo mounted above the engine. Dewitts is one of our vendors and today I talked to them about the biggest baddest rad I can get. 28 1/2 wide by 20 1/4 tall core then add the tanks. Then a shroud with two 12" brushless fans to pull through. IC in the pic is just for simulation. I will buy a Garrett core and then we will weld tanks to it. I still have to fit somewhere a condenser and engine oil cooler. Also possibly a trans cooler if the rad can't do the job. With the 3000 stall converter it will build some heat.How are you going to get air to the heat exchangers?
will there be shrouding around them to keep the air flowing through them & the heat out of the cabin?
I had the truck high enough the wheel was still off the ground. The problem is there is so much offset the inside of the wheel is hitting the upper ball joint. I have a feeling once this thing has axles in it it's going to be a real b**** to get the rear tires off. Might just have to unbolt a bunch of the rear suspension to do it.If you lift the truck higher can you continue you roll it under the spindle so that it's horizonal with the ground?
How much for one ?Small little piece of cold rolled steel responded very well to the torch. I might have to have my big logo cut out of some cold roll so I can blue it. Really like the look. Tried the same size with a piece of hot roll and it did not respond well.
Never thought about selling these. Had just a few made for another project I am working on. Keeping me away from the truck for a week or two. It is turning out amazing. It is cool enough I will do a separate thread on it. Can't post anything yet because it is a gift.How much for one ?
