lincster
- 752
Sean is saying above that mount should go on the other side of the bell housing mount. His suggestion.
Right. If I trim the mount at the line shown I can slide the mount forward to fit in front of the bell housing tabs.Sean is saying above that mount should go on the other side of the bell housing mount. His suggestion.
Copy that.Right. If I trim the mount at the line shown I can slide the mount forward to fit in front of the bell housing tabs.
Nah, if I ever get the itch for big hp I'll step up to a much better car.Nice upgrade !. But,
If you have any intentions of big HP or a V8 in the future skip the 2d and pony up for an S4.
Didn't think of that. Thanks for the heads up Sean!That 104 starter won't work on the 2D BH. It has a longer pinion gear throw than the 101.
If its difficult to pull out of gear while running, that can be a symptom of a clutch hanging up and not allowing the parts inside the trans to unload and pull out of gear.No, car doesn't want to move with the clutch pushed down. When i let the clutch out it travels way out before the clutch grabs and car starts to move.
Oil is Lucas 85-140
