- Thread starter
- #21
Marlboroman
Site Sponsor
- Apr 30, 2021
- 129
- 206
We do all off-road shocks. Fox, King, Walker and others. :ez:Do you just do Rzr Suspension?
What issues have you seen with the Can Am Smart Lock front diff? On my old X3 the ring gear bolts decided to exited the cases after 4,000 miles.Here are some examples of why you should spend some money on transmission and differentials. Spend a little now to prevent the failure, or spend a lot later after it breaks. Polaris and Arctic Cat high gears, and Can Am front diff gears/housing.
(Someone smarter than me can rotate the pictures, they are proper orientation on my desktop, but they get rotated when uploading them)
Diff gears shear the teeth off. The pinion support bearing has too much load on it, and blows out the housing, leading to the bearing failing and falling apart. (We have a fix for this in the works, hopefully here by the end of the year) Along with the typical assembly issues that cause failures by no fault of the user.What issues have you seen with the Can Am Smart Lock front diff? On my old X3 the ring gear bolts decided to exited the cases after 4,000 miles.
My current X3 is a 2021 RC RR. I will stop by your booth and talk to you more.Diff gears shear the teeth off. The pinion support bearing has too much load on it, and blows out the housing, leading to the bearing failing and falling apart. (We have a fix for this in the works, hopefully here by the end of the year) Along with the typical assembly issues that cause failures by no fault of the user.
The newest 2022 rock models come with a new version of the Smart Lok diff that has much bigger spider and side gear teeth. These seem to be holding up well after we prep them in some desert cars. They are impossible to get on their own unless you have an "in" with the Can-Am race parts guy, which I do not unfortunately.
Very Nice!After 4 years of building my '17 3 peddle yxz I am finally done other than a wrap/paint. Just got the built motor finished (thanks Weller) bumped up the boost to 12psi and finished up break in at the cinders over memorial day. I might try and get some new shoes for the sand though but its getting to be a pita to find 110mm wheels and too much $$$ to convert to the '19+ 156mm. Out of all the money and time I have spent on this car, the rear 3" IBP shock replacement was the biggest game changer, I cant believe how much this one change fixes the cars handling.
