AlpineFunco
- 1,065
12 volt power run to the flag mount for the camp marker.
I do believe your the "Camp Host"... Your trailer needs the marker!!!12 volt power run to the flag mount for the camp marker.
Thanks for taking the time to write this out.... I had already covered most of your list, but the rear stabilizer jacks and soar up top is gonna be added!! Thanks againI have owned so many enclosed trailers and most I had built, many from Universal and on each one I found something new I wanted.
Congrats on the new Trailer
A lot was covered above but here is my list sorry its long
Under floor storage. Lights, lights and lights - 110 and 12v all LED
Solar and 2 batteries
Generator auto switch pull in so I can power from the MoHo Generator and 110v outlets
Folding down/up workbench - and if you can get a Vise that detaches
Tool box upfront and a storage tote upfront and upper front cabinets
Compressor underneath 4 Low Profile tanks
Motion lamp by the side door - so I can use the key at night and drunk friends won't stratch the door with key trying to find the lock at night
stabilizer jacks on the back - I work in the trailer sometimes and we set up a big table and do dinners sometimes
at least two roof vents
LOTS of d rings - 4 up front, 4 in back 2 on the sides
Fuel station with an Inside switch and fuel gauge - NO bump out on the side for the filler - its annoying
Spare tire holder inside by the back door - and have them weld it on - not bolt it (I have own 4 new universals)
Trailer winch - the enclosed trailer type - not a universal winch
Back door upper LED lights - really helps unloading
Inside floor coverings are a hard one - LineX is great to wash down, it also hold sand and if do a burn out on it - it sucks to fix and E85 will eat it Vinyl sucks but its easy and cheap to replace every couple years... But llast two trailers I painted the floor with epoxy and jusy touched it up with a roller 2x a year -I think its smarter but not baller
Axles and wheels - I Hate 3 wheel trailers for backing and turning - I like 2 wheel and 5200 lbs axles and 6 lug 16" tires.
If you can do a small water tank and pump with and outside faucet in the wall its great for washing up
electric jack up front is nice too
Walkable roof and a ladder - thats last on the list because it adds weight and you hardly every use it, but they seem not flex as much and they take less maintenance
ALSO painted(coated) factory panels fade fast - the electro dip coating is thin - get it ceramic coated or doo it yourself, and even if you have a front "rock guard" stainless - got that clear bra'd
I did one of the trailers in 2016 and I Painted it with epoxy paint as soon as I got it to my shop - it was a lot of work and expensive, I still see it around and it looks new - factory coating just fades - Not sure what shop would charge to paint a trailer - most people end up wrapping them when they fade and paint is probably cheaper
If you have a Tall Moho
18" extra height - it comes in handy
Stackers are nice if you can town it and have a Tall Moho and have lots of $$$
If you want to break the law (I NEVER would..)
Go 105"
________
Things I hated:
side cabinets - I have a nice scar on my head from that
Fold down couch - it was great to bench race on windy days but took too much room
AC - never used it
Windows - Eff''in thief callers
Diamond plate rear door and runners - looked awesome - Ice skating when wet - I actually removed mine had it Power coated with clear and sand - expensive fix ...
Yep.. Got those!!My buddy added trap doors on both sides of where his rear tires sit. Easy to air up a paddle if it were to go flat. That it was silly until I had it happen to me. Almost impossible to get it out without lots of work.
Those jacks will catch on any low/high driveway you go through if mounted at the extreme rear. Might not be an issue if they are mounted a little more forward. If you need them I'd use the removable hand crank jacks that don't mount permanently to the trailer.Thanks for taking the time to write this out.... I had already covered most of your list, but the rear stabilizer jacks and soar up top is gonna be added!! Thanks again
Another idea that we did to solve this problem was install valve stems on the inside of the rear wheels for emergency use.My buddy added trap doors on both sides of where his rear tires sit. Easy to air up a paddle if it were to go flat. That it was silly until I had it happen to me. Almost impossible to get it out without lots of work.
