Jtmoney714
- May 6, 2021
- 991
- 900
For those with a temp gauge on their cars, a few questions. What temps are you seeing? Do you have an oil cooler? Where is your temp sender located? And finally…. How hot is too hot?
Where is the stock oil sending unit located? I have the Earls one that is in the block near the oil filter. My sending unit for the gauge is on what looks to be the outlet side. My temps I saw were about 275. Never got above that but still seemed high to me. I just have a setrab oil cooler mounted about 6 inches in front of the radiator. I believe it gets decent air flow from the radiator fans. But I’m wondering if I should add a fan to the cooler or if my temps are normal.I run around 230-240. I have a CBR oil cooler with fans.
My sensor is located where the stock oil sending unit normally goes.
My buddy has exact same oil cooler and has his sensor in the oil pan. He sees around 260-270.
I have read before that there is a 30 degree difference between the 2 points so this makes sense.
I don’t run a thermostat in my oil cooler line, I know some suggest it. But I also warm up my motor and don’t run hard until my oil temp is above 150.
Anything over 300 or so I would be doing an oil change soon after that temp.
I'd be real surprised if that was accurate.I have a racepak dash and a Mefi computer. The racepak says i'm at 230-235 when running hard. No oil cooler, 408 LS2 Stroker. Thought about adding one but after reading this I don't think I need it.
Where is your temp sender located?There was a good oil temp thread before the crash. Oil temps above 250 with regular oil are not recommended. Optimum is 215 to 225 range. With synthetic you can run higher of course. Before I put the cooler on my car I was getting oil temps up around 275 running hard. Now that I have my cooling system working correctly and a good setrab oil cooler my oil temps typically are in that 210 to 220 range. Lots of good info online that you can research.
Just dropped my car off with Karl at shock talk. He will have it for 2 weeks. I don't remember where I put it.Where is your temp sender located?
