onanysunday
- May 7, 2021
- 3,882
- 3,527
So I have a 99 National Tradewinds with the Cat 3126. The two engine starting batteries are group 31 in size. Just got back from an 8 day trip and every night I would charge them up to 12.7-13. Overnight and in the morning the two batteries would be discharged to 11.7-11.9 volts. Drove home yesterday and parked it. After letting the coach sit a few hours the batteries were showing 12.7. This morning they are checking at 12.4 along with the (4) 6 volt house batteries also checking at 12.4. National is running the fridge off of the two starting batteries. That is the only thing I turned off last night so the fridge is the main draw pulling it down. It is running on propane but obviously it has a 12 volt draw as well. (Looks like 2.7 amps). It is a Norcold fridge and here is the tag. I don't remember it drawing the batteries down this fast but maybe I was running the big gennie more often. I believe it charges at 40 amps.
So I need to do some kind of solar. Don't want to spend a fortune on a system. I will say I like to play the stereo in camp and the Fosgate amp will draw the 4 house batteries down as well. What about this Renogy 100 watt portable panel? https://www.amazon.com/Renogy-Watts-Monocrystalline-Foldable-Suitcase/dp/B00LXG4AXS?th=1
Seems reasonable in price and I don't have to wire the whole coach. How fast would this charge the two group 31 batts and then the 4 6 volt batts? I would just extend the wires if needed and connect with alligator clips. Don't want a controller if not necessary. On a nice sunny day would the 100 watt panel charge the group 31s in lets say half a day and I could switch over the the house batteries and give them a charge as well?
I do have a pro series DSR145 which I run off of the 2000 little gennie. Intermittent 40 amp charge that will bring them back up in an hour. But a PITA to do every day. https://www.schumacherelectric.com/products/dsr145-6v-12v-125a-proseries-battery-charger-engine-starter/
