the 2500 mile trip begins, working on upgrades 2017 X3
The daily is awesome. Look forward to seeing every day. Do you guys have a starlink or just getting lucky with service every day?
The speed car has star link but we are in remote motels in small towns. The speed car blew a ps pump so we had to go down into manti and gram and find a belt to bypass his pump for rest of trip
210 miles! Crazy day both awesome and some serious issues with speed car. Working on some Mac guyver fixes and will keep you posted Riding the Rim for 100 miles was absolutely spectacular! Spent most of the ride between 8000-11000 feet
Up on the 100 mile ridge the speed car had a bad hydraulic leak near the motor. There is no way to fix this leak in the road nor could we drive 30 miles to the nearest towns. Manti and Ephram so we removed the belt but now he has no alternator either but at least we could proceed. He was watching his voltage and got down to 8 volts when car shut off in Manti. But all the stores were closed because of a state holiday. So we jumped his car for 15 min and he drove to Ephram Found a correct belt to run only alternator, ate lunch and went back up the hill for the remaining 100 miles
But during a stop the owner said his steering is so tough that he can’t do another day like this. My Mac Guyver kicked in. The reason is the ram and servi are still filled with ps fluid. With some thought we disconnected the ram lines and turned the steering to push the remaining oil out and hooked up a crossover hose so the ram can now move and not be under a constant hydraulic lock situation. Capped off the pump supply and return lines and wrapped a plastic bag, electrical tape and zip ties around the servo to keep dirt out.
He still has an additional electric power steering so I think he will be ok
At approx 1500 miles so far. Today we go through 3 states. WY, Utah, Idaho. Be close to bear lske. 160 miles. All cars still running. Got in early yesterday. Went to the movies. At it again this AM. Leave at 7:30. Pack a lunch. No gas on the entire ride. My 15 gallon gas tank and 12 mph has been awesome. What would I change on my car so far is a larger or thicker radiator as there have been times even in cooler weather while climbing huge mountains my temp has got to max (7 bars). I don’t know if my dash has an over heat light but I did have to pull over twice because the temp was uncomfortably high to let it cool off
From our ride host about the ride tomorrow:
FYI: tomorrows route is great: Skyline Drive (often just called "the Skyline") in central Utah, it is one of the finest high-elevation backcountry drives in the western United States and a favorite among adventure motorcyclists, SxS riders, Jeep owners, and ATV enthusiasts.
Overview
Skyline Drive follows the crest of the Wasatch Plateau through the Manti–La Sal National Forest, stretching for more than 100 miles. Much of the route stays above 10,000 feet, with long sections riding directly along the mountain ridgeline.
What makes it special?
Spectacular 360-degree views across central Utah.
Long ridgelines where you can see valleys on both sides of the mountain.
Huge aspen groves that turn brilliant gold in the fall.
Alpine meadows filled with wildflowers during July and August.
Numerous small mountain lakes and excellent camping opportunities.
Frequent wildlife sightings including elk, deer, moose, hawks, and eagles.
The road
Skyline Drive is primarily a graded dirt and gravel road.
Conditions vary:
Look forward to being overwhelmed and bewildered by the striking beauty of nature God created.
Crazy day today but did not disappoint. Was supposed to be 160 but did 222 miles. Did ice cave but wasn’t much. We accidentally went through some private property a 25000 acre ranch. We had 5 of us taking down a fence on the far side and went through. But the lady on the trip is solo and got caught and locked in by the rancher. He called the sheriff and she was there for 2 extra hours. They didn’t sight her but could have been $800. We went up a super steep slow climb that was very narrow. The kind that is so steep if you stop you are almost sliding back down. The lead guy didn’t want to continue. We had to back down this crazy steep hill backwards and there were some deep rain ruts. Like 18” yo 3’. We could not see anything behind us. My back tire stopped 3’ feet down caused my left front tire to come off the ground a foot. My car was teetering badly ready to flip over and roll down a huge hill. My copilot was spotting RT he other guy. I had to go alone so backed down more and my front tire went in the same groove. Putting me at a true 45 deg angle to the right. The only thing that stopped me from now flipping was the face of both right wheels was touching the other side of the rut. All went well. Got in to the motel and 20 min later started pouring!
exciting day!!!! That sounds really sketchy backing down. Sometimes better to continue up.
We did a stupid steep climb out in Cal City at the end of canyon called Last Chance. We hung a left and went up this mountain and it dropped us down in front of the Burro Schmidt mine. When we looked down after all were up and safe we all said that was a really stupid climb to attempt. LOL!!!
I wanted to go up more but our leader had second thoughts. It turn into chunks of shale rock with exposure up higher. It was bad.
Damage report today :
Speed car lost half of the info on both gauges like water temp and air temp etc
Another pro R would not shut off. So far drying her connector has not helped
Turbo r razor had a CEL with a code for “ low current draw on a circuit” or open. But doesn’t say what circuit
Another pro r lost his cvt belt
Another guy was drilling and extracting some broken bead lock bolts and drilled too far and into his rim
Another guy rotated his tires
And I simply checked my oil and it was perfect!
