- Thread starter
- #181
Rockwood
- 8,727
Naw. There’s nothing behind it I want air hitting, and adding air behind the radiator reduces cooling capacityGonna cut the vents out?
Lol. Didn’t you see my heat shielding? These clogs are coooooooolNaca ducts. Tubes down passed the headers to cool them more. Keep those tootsies cool. Guessing you have the "high" performance jobbies though...
where did you purchase that exhaust wrap material looks good i need some to wrap a water line right above my turbo on my 2013 duramaxView attachment 186842
Final product. There is a VERY noticeable difference in temps of objects near the exhaust where there is wrapping and not. Put your hand on the “frame” next to the wrapped exhaust, cool to the touch. Next to unwrapped exhaust, barely bearable to touch.
So you can not wrap a heater hose with it? You’re saying it will melt my hose ?Amazon.com: 2PCS Exhaust Heat Shield Automotive Kit 16" x 39", Embossed Aluminum Heat Shield with 20PCS Cable Metal Ties for Exhaust Wrap Heat Shield, Car Exhaust Sheet : Automotive
Buy 2PCS Exhaust Heat Shield Automotive Kit 16" x 39", Embossed Aluminum Heat Shield with 20PCS Cable Metal Ties for Exhaust Wrap Heat Shield, Car Exhaust Sheet: Heat Shields - Amazon.com ✓ FREE DELIVERY possible on eligible purchasesa.co
If you wrap anything melty with it, make sure to leave air gap. The shielding itself blocks heat from passing through, but it definitely absorbs it. Anything in direct contact with it will fry.
I would place it between the hose and the source, or wrap the exhaust partially. The heater hose doesn’t need to be wrapped to be protected, just blocked from direct radiated heat.So you can not wrap a heater hose with it? You’re saying it will melt my hose ?
That trail is tough, you like self inflected torture huh?
Still bet it was a fun day wheelin, how was the weather?
Lol, 4WD still worked, amazingly.Those gears have at least one more run in them. LOL!!!
Snowball is the problem. I ditch the 30 for what? Not much out there that’s 60.5” WMS other than a LP Dana 44 from a TJ Rubicon, so I’m swapping both axles to match…Maybe ditch the 30...
