Honda TRX450 Duner Part Out
Morgan
Consolidating after an unexpected family death and won't be going back to the dunes for awhile. All parts listed are new, never ridden on, located in Mesa, AZ but will ship some of it on your dime...
2005 Honda TRX450 frame/subframe, clean AZ title with legible VIN tag, all un-needed tabs removed, center gusset removed, powder coated Misty Midnight blue, all frame/mount bolts are Ti64 titanium, all fender brackets cerakoted E100 Blackout, all motor mounts are cerakoted burnt bronze, LSR stem to chassis clamp -$1200
One off MRP Honda TRX450 +6 swingarm, PC Misty Midnight blue
PEP big bottle rear shock, Misty Midnight spring, burnt bronze cerakoted clamp
LSR billet carrier with Worldwide ceramic bearings, E100 blackout cerakoted
LSR caliper plate, E100 blackout cerakoted
Delrin solid pivot bushing kit
OEM Honda front slider, ProBolt aluminum bolts
Hand cut TM Designs rear slider
LSR brake line clamps, E100 blackout cerakote
All bolts pictured are Ti64 titanium
All parts are new, mounted for mockup pictures only. Will work on any year from '04-14 as shown. Will throw in a free DID ERT3 chain for a no BS buyer.
Will not split up, designed on these specific parts- $2500.
JJ&A Racing 34" billet play axle, cerakoted E100 blackout, hubs are burnt bronze, all hardware is Ti64 titanium- $800
DB Fab Ti footpegs, with Ti64 titanium bolts- $300
'08+ER fuel tank, petcock, new heatshield, new OEM white cover- $400
Renthal Twinwall 918 CR High bend 1 1/8" handlebars- $120
Rear caliper, rear master cylinder, cerakoted E100 and burnt bronze, Ti64 titanium bolts, ProBolt aluminum banjo bolts, Faast spring clevis, new OEM full rebuilds on both- $250
Rogue 22" 72RO 7 paddle rears
Direct Drive Element 8x8 rear wheels
Rogue 21" Mohawks
Rare JJ&A 3 spoke 10x4 front wheels/hubs
Ti64 titanium hardware
Wheels powdercoated texture black
Front hubs are cerakoted burnt bronze, and they do not have provisions for brakes, this is a drag race/fast duner setup.
Will not split up- $1500, can throw in a set of shaved and cerakoted '04/05 spindles as well if needed for a no BS buyer.
Also have a full engine as well...
575cc 102 bore/6mm stroke combo, new OEM cases smoothed, bored and trenched, PC texture black, new +6 OEM crank with Carrillo 111 rod bushed down to a 19 pin done by CWI, CPI 102 cylinder, CP piston, full ISF transmission and bottom end gears, DD lockup with custom cut kicker, new OEM clutch, new OEM bearings, ARP 12mm studs, MRP oil cooler delete, etc...exactly how we do all of our 80+ HP builds. Will come with RE big intake, misc burnt bronze covers as well. Can include free harness, condenser, voltage regulator, coil/plug cap, Pro Design kill switch if needed.
$4000.
Too bad most of the guys on this site are out of shape, can't actually ride anymore and sit behind a steering wheel. This stuff would have sold in days, a decade ago.
You could just say, excellent items for sale, the level of this stuff is amazing as we both know.... coming from Quads.
You could you know..
Appreciate that.
Parts are a little on the pricey side but this was intended as a final personal build and wanted to do something all out with no corners cut or expense spared whatsoever.
I would love to take all of this off of your hands, but I can’t.
I will put the word out, though.
My apologies for muddying up your for sale thread.
