Laserguy
- May 6, 2021
- 29
- 43
Finally got the flex fuel tune all dialed in! The car was setup for flex fuel but originally just tuned on 91. But I had a couple issues getting the e85 tune dialed. First flex fuel sensor issues. Then the O2 sensor failed. The final issue was blown out spark. The stock LS coils “round ones” didn’t have enough juice to keep the spark going at high boost and rpm. I upgraded to the Holley Smart Coil kit with the big wire kit. It solved the issue and I was even able to increase spark plug gap.
Here are the 91 numbers to the wheels at 10psi before e85 tune.
Holley Smart Coil upgrade
E85 dyno run
IMG_5204.MP4
Any guess what the WHP is with E85 and about 18psi?
E85 dyno run
IMG_5204.MP4
