Mill Work in San Diego / Ramona?
wesinls
Last trip out had I had a micro stub bearing fail and as a result my caliper was damaged...I bought 2 new calipers and went to install a found out the previous owner milled down the calipers about an 1/8 of an inch...I need to do the same to the two new in order for them to mount properly.
Anyone know of a shop in Ramona or San Diego that could mill down these two surfaces? (on two calipers). I'm assuming a mill would be the best tool for the job.
I would give Wilwood a call and ask if they have the offset you require. Even if they have one with an offset greater than what you need, shims are provided to center your caliper on the rotor.
Too late as i started to grind down one of them...stopped after a few minutes as I realized it was a bad idea, ghetto as f. But ya, IF another one was available and shimming - would be ideal. After I get these milled I'll still need to shim them to make it perfect.
Yeah, don't do that! The caliper needs to sit flush and true to the rotor for best performance. Call any machine shop near you and they can bang it out quick.
Ya, was trying to rush and after about 10 seconds, stopped my urge and put down the crack pipe.
I found someone local to help out.
