Building a new trailer. What are your must haves?
Horsepower Lifestyles
Well I probably should have started this thread sooner because I'm already in the middle of my build but I have time to add stuff. Building a 28' universal stacker. What would be your must haves? I think I covered all of my boxes but just seeing what everyone else recommends.
Escape door, loading winch, rear door winch, spare tire in floor, pre-wired for solar or solar, hydraulic tongue jack, fuel station,
104" door opening
I have all the basics plus some extra goodies, loading winch, rear door winch, Not sure where I'm doing the spare tire yet. My old stacker had it in the floor only problem was my car was on top of it so if i needed to change it I would have to pull the car out. I may do a wall mount. Pre wiring for solar might be a good idea. it does have a generator compartment in the front and I always run a generator. Hydraulic jack is a good idea too, i think I have a standard electric jack at the moment. I did 2-70 gallon fuel stations with a hose reel in the front compartment. also did 100 gallons of water
Solar 100%
Even if it's only a 200W panel, you can always add panels but nice to have it already installed and wired and keep the onboard batteries charged etc.
In my next trailer I want to add 100 gallons of fresh water and at least a 50 gallon grey tank to drain the motorhome into the trailer for long trips.
hmmm I like the idea of having the grey tank to drain the motorhome into but that sounds like alot of work to do in the dunes and then I have to dump the trailer when i get home too lol
Assuming you already have an air compressor going in? My new trailer has a 25' fuel hose reel and 50' air hose real in the same box accessible from the outside / near front of trailer.
If you always like running a genny then solar is a non-issue, but with that said I had solar on my last trailer and loved it (never had to plug it in or worry about it) so I am in the process of adding all of that to my new to me trailer (keep in mind if you go this route you need an inverter etc
you putting in plenty of cabinets and a big tool box?
I will be moving my spare tire to be mounted hopefully underneath the very back of the trailer.
new trailer has a small sink in the work bench which drains straight under the trailer... definitely excited about this since I always need to wash my hand when loading / unloading / working on stuff and beats having to get the motorhome sinks dirty / waste grey tank capacity.
new trailer has 190 gallons of water which is overkill lol... only 60 gallons of fuel, but I would like to add another 40-50 gallon if possible.
escape doors are awesome to have
Random storage, like for extensions cords or things you don't use much.
