onanysunday
- May 7, 2021
- 3,882
- 3,527
1999 National Tradewinds. Freightliner chassis which there are a ton of on the road. Second set of tires I have put on this coach. First three corners of 8 big 30mm lugnuts torque just fine. Then on the last rear double wheel bolts just keep spinning and won't torque. Not 1 but 4 studs are now spinning in the drum. So now I need to pull this apart and either put in new studs or spot weld the back side if I think the weld on cast iron will work. Strange but true. Anyone ever see this? Oh and I am not positive but thinking the drum should slide off when I pull the dual wheels? 450lbs torque on these big lug nuts so I will need the tire guy to come back after I fix it.
