Thinking about electric power steering on my Gen 4 Funco. If you have installed Electric on your buggy please share.
What system does it run as far as a rack and the unit model itself?
It has the normal Extreme labeled rack (not sure who actually makes this rack for them) and a 400W Electric Motor, not sure of the brand, I would have to pop the hood off to check. I'm running 33's on the front but I know he uses the same setup on 35's as well.
If you're keeping a hydraulic rack, you can just loop the lines to keep everything lubricated, but disable the power assist.
I will be going to a manual rack if I go this route. Although I did not think of that. Cool.
You now have me thinking. I could easily put my Gen 4 rack back together. Teeth have some wear on the center teeth where it rides going straight but not horrible. Normal wear from the amount of miles on the car. For sure the aluminum for my spool valve is considerably worn and Grant has an upgrade for that if you keep the stock rack. The two aluminum machined blocks at each end are now unobtanium. I believe he said 2008 was the last year for that rack or those parts. Mine have some wear but I think the could be sanded and used again. It is not a load bearing surface. I did have one boot full of oil where it went past the two o-rings. Anyway I digress. If I put my stock rack back together and just packed grease in for the gears I could then in my case put the EPAS unit inline of the steering shaft. That would be a ton less work than putting in my gear one super rack which will be out of the truck this summer at some point. That project will be probably 100-150 hours of labor alone.
The gear one rack has a recessed area and I had built my mount to drop down in to that. Super strong. Guessing I could cut that piece off of my chromo cross tube and re-use. The spreader bar would be really easy to build with two pieces of flat long plate and spacers between. Then the heims go in between the pieces on each end. I would like to put the pivots in the same spot so the geometry stays stock. Going down the rabbit hole of playing with bumpsteer is a pain in the ass and above my pay grade. I would imagine this rack is super beefy as far as gear size. Good question I will ask Parker because I know what size the stock Funco is. Although I have not heard of gears ever breaking in a Funco rack. Decisions, decisions.
I think the Funco rack is a modified OE rack from somewhere.
But yeah, all of us import racers would just loop the lines to remove PS drag when a manual rack wasn't available. The rack on the USTCC racecar has been looped like this for 20-30k race miles now. Really no different than when you first install a new rack and cycle it back and forth a bunch of times to bleed fluid through it.
I have the Kartek eps unit, too lazy to build my own and i couldn't get ahold of other people that sold them. The one my car came with never worked correctly, so I bit the bullet and changed it.
I had read somewhere that jump starting a car can mess them up, so I put it on a breaker to shut it off just in case. Don't know if its true, but better safe than sorry.
The Gear One rack should work fine. Both the Funco and Gear One rack are 1.5 turn to turn on the wheel. 3 3/4 inches rack total travel on the Funco and 4" on the Gear One. So from center 1 7/8 to 2". Only 1/8" difference. It will be a lot of fab but I might as well use parts I have.
Goodies that will be going on the truck. I will start that project in a couple months and then the buggy will come after that.
I will add to this thread that Grant has multiple options to fix your Gen 4 rack if it breaks. In my case I already have these parts and also I'm willing to do probably a good amount of fabricating to get it all put in there. If I had to hire someone to do the labor it might not be worth it.
I have a couple of friends that constantly need jump packs, no issues with their EPS units failing.
I do have the EPAS electric power steering on this car and absolutely love it.
Was thinking about how much crap gets removed from the car. This guy sums it up.
Not to far off from yanking the gear one rack and epas unit from the little rusty wagon. The epas is the most powerful unit on the market but would not turn the 295 wide front Toyo 888rs well enough. I was orginally going to install the Howe stuff in the truck first but thinking I will attack the buggy first. Try have it ready for next season since I have missed so much dune time the last 4 years.
Phase one of this steering project. Blitzkrieg unit in and was able to put the steering wheel in the exact same position as when the car was built. I just stayed with the grant wheel that came with it. Cut the flange off the original shaft and left about 3/8 of an inch. Took about a two and a half inch piece of 1/2 in tubing and had to remove about .003 off of the od. It pressed into the blitzkrieg shaft and the steering wheel flange. It will be butt welded and Rosette welded. Won't do that until I clock everything so I can still turn the steering wheel and get it perfectly straight before welding. Much better than the original bushings that get sloppy over time. Same 48 spline shaft coming out. Anyone could do this at home with a welder and grinder. That 2 in od tube is a little bigger diameter than what the car had and I just laid it up against that crossbar and welded it in place after lots of measuring. Then added the two gusset pieces.
This car is 21 years old now and I never had an issue with the original Grant wheel that came on it. I was looking at Momo Wheels which of course are a little better but ended up finding a New Old stock of the exact wheel that came on the car. $80 versus $250 for the Momo. Just fine for me.
I was over at Fodrills and had looked at this little 6-in unit with roller bearings. Then you just buy a shaft that goes in there with the same 48 spline. Apparently these used to have a little seal but now it doesn't even have a seal on it so the sand would kill it. This thing is $50 and the blitzkrieg was $175. Well worth it and seems like the only thing out there that would work other than Heims.
