Small crane truck in S. PHX area.
Kraut_n_Rice
Site Sponsor
I'm looking to get a 10' shipping container lifted from my front yard, over a 7'~ wall, and set down just inside the wall. My house is on a corner and all lifting can be done from the street. Maximum reach would be about 20', and about a 25-30' swing.
Any hook ups?
30 ton boom truck can give you (roughly) 10 to 11K pounds @ 30’ , maybe a bit more or maybe a bit less depending on how much boom they need to squirt out.
You have Marco Crane in phoenix, give them a call and get a quote.
They might even have a something smaller and cheaper for the capacity you need.
Thanks. The container would be empty, and according you google... it's around 2500lbs
Yeah, something that small can definitely use a smaller crane.
Whatever crane they have available I’m sure would be quoted to your needs.
I know I’m a Californian…
But how’re the container laws in your town? They’re cracking down even out here in the sticks.
Couldn't tell ya specifically, but a guy a few doors down has one in his yard. Has a HUGE pole tent thing covering his pusher on the other side.
Think I'm good. LOL
I will be calling Rapido here in a couple weeks as well I need a generator set on a job site.
You can get better pricing also if when you call let them know your flexible on the time/ day.
I used Rapido to set an AC unit on my house last summer. They were great - it helps to know Spanish. This was on a Saturday and thats the only reason I did not use my buddies down at Shaffers Welding. They are close to your shop (and mine) but I don't know where your house is. They would probably be close to $250 but don't quote me on that.
Shaffers Welding (602) 273-0869
My Spanish is enough to order a beer and find the bathroom to return it... Was their English good enough to stumble through it?
We've moved since you came by, but I'm only at 16st/Baseline.
When you get to the point where you could get a pic of the container, pm me that and your address if you'd like. I can do a pre-site using google earth and also recommend how to rig as those guys I would assume do ac's and truss' primarily. Problem is that a 10' container may be a 40' shortened and only have lift points on one end unlike the one in the pic (neighbors) where you could get away with (4) 10-20' straps and (4) 1.5" shackles.
Tough to tell with the shadows, but it would ultimately go in the orange box.
Yeaaa, you'd be fine. More so when the operator got out to my house is when the Español came in to play.
