ESCO
- May 4, 2021
- 22,335
- 10,007
Some old farmer is into sanddrags..Racing sand this weekend in welton arizona
Racing asphalt in phoenix Jan 24-25th
back to welton az feb 20-22 for sand
And to Las Vegas feb 27-29th for asphalt
2.73 second pass, lifted at 2.49, lost coil number 1 at 1.6 secondsVideo or it didn’t happen!
You can hear when you lose the coil. What kind of coils and ignition system do you use?2.73 second pass, lifted at 2.49, lost coil number 1 at 1.6 seconds
That had a 3.81g load at the shift to 2nd
It’s gonna get up to speed next race
Fueltech ft600 and fueltech coilYou can hear when you lose the coil. What kind of coils and ignition system do you use?
Primary wire/crimp failure. Install issue, stupid issue. Did not have proper tools at track this timeDid the coil fail, or plug wire/circuitry issue?
Just curious what tranny you have in your car. How much does the car weigh and what size cv joint do you use?Racing sand this weekend in welton arizona
Lenco trans, quick change rear end from b and j engineering, hollow aluminum axle (no cv joints)Just curious what tranny you have in your car. How much does the car weigh and what size cv joint do you use?
