CNC clutch pedal stop Idea’s
ChasingSand
Need to make a clutch stop on my CNC pedals. Was thinking of welding a barrel nut to the pedal and adding a bolt with a rubber stopper. Problem is I don’t have a ton of time to do this as I leave on Thursday. Anyone have an easy solution?
i use this one...its on other sites for cheaper - but this is who I bought it form in 2020.
Replace the top master cylinder mount bolt with a longer one and double nut. Adjustable, quick, and easy
This! Exactly this. I used 3/8 threaded rod, double nut to tighten and cut at the approximate length and then adjusted accordingly. Pretty straightforward and best mod ever!
