Will it fit in the T/H?
Get415
Anybody able to fit a Turbo r4 in a 13ft garage model toy hauler? I currently have a turbo s 4 but i belive the R amd new Pro s are quite a bit larger. Thx
I believe the 4 seat Turbo R/Pro S is a around 13' 1" long.
2026 Polaris RZR Pro R
Overall Length: 136.5 inches (\(347\) cm)
Overall Width: 74 inches (\(188\) cm)
Overall Height: 72.8 inches (\(185\) cm)
Wheelbase: 104.5 inches (\(265.4\) cm)
2026 Polaris RZR Pro S
Overall Length: 128 inches (\(325\) cm)
)Overall Height: 74.4 inches (\(189\) cm)
Wheelbase: 96 inches (\(244\) cm)
If it’s just an inch or two, let some air out of the tires and ratchet it up tight against the front wall and slam the rear door shut.
No need for tie downs. 😝
I like the way you think!
Those are the specs in Stock Tire trim.
Sand tires change those dimensions. That was the case on my XP4 900, anyway.
He's probably going to need another 4-6 inches (some of you may have heard this one before... 🤣 ).
Challenge accepted. Thanks for the info gents
