Desertanddune
- May 9, 2021
- 86
- 8
I believe my fuel pump died there are no markings on it how do I identify it and where can I get a replacement
Scorpion car with shortstar
Pictures would help....
Thanks john its a stock short-star needs between 40- 50lb fuel pressure.that is a bosch pump. it's not an 044 as they have an 18mm inlet
next you should be spec the HP of the car, turbo or not. if you are in OC we can help you with that too
both of those pumps listed from Kartek are 5/8" inlet not common for most buggies and hard to adapt if you have 1/2" hose now.
if you have a 1/2" inlet we have a Bosch pump with 1/2" inlet and -6 outlet $200 or even a bigger AEM pump if needed for a little more
But I found it wasnt fuel pump , fan ground shorted and took out Fuel pump relay now to find a replacement relay
I got a superseded part number on 044 and couldn't find that pump anywhere local in ventura county .
So after Thanksgiving im going to order a new one and keep this one for a spare
