- Apr 30, 2021
- 4,870
- 1,823
Did you fix your car
I been doing more reading on it myselfTaking it to my buddies house tonight to plug it to the computer. I checked multiple things and couldn't find anything. Should know more tonight.
Me too and tried multiple things, but its at a point that I need to plug it in to a computer and check sensors and clutch pressures. Should be able to pinpoint it and know for sure. I don't want to keep throwing parts at it or pulling things apart that don't need to be. Fingers crossed I find the problem tonight and I can fix it quickly.I been doing more reading on it myself
Looks like one of the 6 spiral seals between the clutches failed. I'm getting pressure in both clutches at the sametime. You should only have pressure to clutch 1 when using 1st, 3rd and 5th gear. Clutch 2 handles 2nd, 4th and 6th. I have pressure in both and it wont allow it to shift to second. It's not a good design to install and hope you don't nick a seal. I must have done that and it worked for a day and a half and then failed. Got the seals ordered and should be here tomorrow. Should only take me a few hours to replace because this will be my third time going into the clutches and I'm getting good at it.So what did you find out on the car?
Well even though way over my head that makes sense on what the Issue was..Hope you get it back going for T-daySo the two Number one seals were smoked.
