looking for a little help, need a pulling ram set.
John@Outfront
Forum Moderator
i have a small project with some bent metal on one of my tractor trailers. i bent some 3/8 steel plate holding my fender on while loading. i need a 10 ton or better come a long or better yet a hydraulic ram with hooks on both ends. i do have an "Enerpac" air over hydraulics unit but only have an extending ram.
was wondering if someone in orange county or the inland empire might have something i could borrow? i might have it for a few days but would only be used for 30 min
Well all I have is 3 6 ton cumalongs. Your more then welcomed to try it out. 949 357 7346
Can you just run a rigging chain over the ram and hook the chains up to the plate?
Picture?
Adam909 helped me out bigtime. Met up with him last Saturday and gave me one to try out, im excited to use it. I had no idea how huge the hooks are on a 6 ton come along!
Have you tried talking to it????
We'll make it better.....
"Ok! Show me!"
those come alongs are serious probably rated for overhead lifting with a 2 to 1 or 3 to 1 safety factor
I got more practical 3t if that 6t is too big. Just imagine working with a 10t. 1. 16-LB025H-3.jpeg
Well it worked very well. Got it 90% pulled back. Used oxy/acetylene help. Used both 1.5 and 6 ton at the same time. That 6 ton was barely breathing. Thanks again Adam!
