Starter for j35??
Ganzo
Ok this may be a stupid question. I used to have a subi motor attached to my 091 trans, i swapped it out for a j35 and used same tranny and starter. Heres the dumb question, should i have swapped starter when I changed motor? My starter I think took a dump (will verify tomorrow) and i want to know if i messed up
Depends on the starter you had.
I had issues with an under-wired circuit feeding the starter relay eating the starter relay. Ended up swapping to a relay to feed the relay and issues were solved.
Been using the standard imi hi torque starter without any issues.
When I first did the swap I had the odyssey 680 battery it did great cold or cool but couldn’t hot start if I shut car off and tried to restart asap.
Switched to the 925 battery no issues.
