Variable Speed Electric Motor / Voltage Regulator
Prob about 50% or more...it's scary how fast it is now. We havent even put the horses on it yet....maybe the VFD is the better route? I only have 120v tho.
Something like this?
Based on the partial wiring schematic pictured, I think that's going to do the same thing as the controller you already bought. It appears there's a 3ph hookup schematic off the picture to the right. If so, a single phase AC to 3ph VFD controller would work perfectly.
*** EDIT *** NM. That's a capacitor start motor (assumption since it says capacitor motor on it), VFD won't work either.
You're either going to need to replace the motor with a VFD compatible motor, or pulley it down.
Late to the party, but ...
This is the sorta thing I use ChatGPT for. Give it as much info as you can, it it will probably come up with a solution.
For electrical stuff...
I like this place: https://www.digikey.com/
Can you show the schematic for (assumption since I see amps drop, 20X voltage, and the single phase hookup shows waaaay too many inputs and lines for a single phase only motor) 3ph hookup? It's possible the capacitor is used in single phase only to help with startup current. 3ph usually doesn't need a cap to start...
For the motor, not the VFD :)
Not sure if this is correct or what you're looking for - but similar part number (mine and this one start with 5K565)
And on my actual unit is has:
The motor he has is only single phase not 3Ph. It has two configurations, Single phase 120-volt or single phase 208-230 volts (208 volts is present when you have a three-phase service and 230 is single phase)
Decreasing voltage (10- 20%) in an electric motor like that will work, decreasing it much further will decrease the life of the motor
Yeah, you’re right. Got wrapped around what looked like a Y hookup and 208v and went with it…
Thoughts on which one of these has the best chance pf actually solving the problem. The second one showing a max output of 3.5a makes me a bit nervous as the motor specs I have state 6.5a at 220v.
~$300 gamble either way.
https://www.grainger.com/product/DA...earchQuery=55ac15e&searchBar=true&tier=Tier+6
Not going to work!!!
3.6 max amp output, your motor pulls 13 amps per the label, now it does pull 6.5 amps at 208- 230 volts but THATS NOT WHAT YOU HAVE OUT THERE AND THATS NOT HOW THE MOTOR IS WIRED. Your motor pulls 13 amps and it is going to thermal that thing out faster than you read this post.
Thanks -do you feel the same about option 1?..15 amps on that one.
