Update Your Old Laptop. (Parts are Cheap)
JDMeister
Forum Moderator
Laptops Today.
It's true. Ram and SSD prices are lower that thy have been
for years. Last week I priced 128 gig SSD sata for $9.00 to $15.00 ea.
With Windows stopping update this October for Windows 10,
it possible to install Linux (It's free) and it will run faster.
1) What you need to know before starting.
Check the model number of your device. Google "Max ram" and HD connection.
Drive should be "Sata" and ram could be "DDR2", DDR3, or DDR3L.
DDR3L indicates "Low Voltage". Make sure you know what you have.
If you machine is DDR4, it is a bit newer, but if you are running Windows 10,
read this again a few times.
(There are ways to upgrade from Windows 10 to 11 even if your machine does not
qualify. (Per M$)
I have some DDR3 and DDR3L ram and some SSDs. Available cheap.
Kit: 2 x 4Gig DDR3 or DDR3L ram (8 gig) and 1 x128 gig SSD $25.00
Kit2: 2 x 4 gig ram, 1 x 256 gig SSD $35.00
(5 kits available now, more coming)
Most laptops will run faster with this simple update.
Are you taking units in for upgrade?
Yes. If it boots, it is eligible.
The truth is, older hardware is almost as good as the new stuff.
Mfg companies reduced the power requirements on new stuff not to make it faster, but cheaper to build . Unless a system is an older "Core 2 Duo" with a max ram ability of 4 gig, it should be fine. I suggest checking the model number on the google and ask "Max Ram". If the answer is 8 gig or better the system is perfectly able to upgrade.
Slip in an SSD, make sure at least 8 gig, install fresh OS. (Your choice)
What if it boots-ish? Maybe I just need to send it to you to have a peek at.
The best shipping container is the FedEx (Kinkos) outfit.
Solid cardboard, foam insert to protect laptops.
