Mac
- May 3, 2021
- 1,268
- 2,630
I tried two different vacuum style bleeders like that one and couldn’t get the air out. I went with a positive pressure style and it worked much better. Only issue with these is you maybe to make a custom cap to fit your master to attach the air feed hose. I went with this one and it worked great:You Can't go wrong with this harbor freight bleeder, My car for some reason had a issue with air getting trapped in the cutting brake, I broke down and got this from harbor freight , It will suck every air bubble out of your lines, It is a little expensive but it works great.
If you just let it sit for a second, will it lose pressure and go back to a soft squishy piece of carp? If so, you have a bubble.It's clamping and it's firm. Then you move to the next caliper and nothing. So then you bleed and build the second caliper up...back to the first and nothing.
Hey man, you axed.
Never thought of this and putting the dot to the topyou can use a thera gun of some type of vibrating deviceand run it over the turn brake or any other problem areas that are believed to trap air.
