Deviantduner
- May 10, 2021
- 104
- 167
Holy shit balls! Didn’t think anyone had done this to an ultralight. More info and pictures please!! Who did the fab work?At some point if you swap out the front arms, you can fit bypasses too. Bypasses on a ultralight make it a completely new car
View attachment 141668View attachment 141669
Did you still use the 8” coil and add the 10” bypass? Who did the work? My car is at SU right now and they are fitting both a 10” coil and bypass but they have to lift the mid rail and shock mounts plus new arms to make it all fit.At some point if you swap out the front arms, you can fit bypasses too. Bypasses on a ultralight make it a completely new car
That makes sense now. Unfortunately my car already had kings all the way around and Bypasses in the rear already. I am pumped hearing about how much better it handled and the ride quality improvement.Ed at SU did the suspension work.
King Adam did the body
If I recall the fronts are normally 9in.
I got all new shocks and bypasses - custom made 4 tube bypasses for front ( they were a 1 off )
Kings lengths don’t work very good for SU and fox stopped making the small ones. Hence why Ed has to raise mounts
Either way, with new arms yes they can fit, car will be wider, but that just makes it drive even better and gives more travel
Started life as pristine SU UL
Then king Adam, outfront, and SU did their thing with cubic dollars thrown at it
Then revamp again w ls3 and went all black. New owner still runs it around glamis
X2If I can make a recommendation for the shifter, I would ditch the one you have and go with a pro am unit. I tried adjusting the old one and could never get it right.
I was going to reach out to you to ask about the shifter since you have a similar car. Getting a new shifter is not in the budget right now so will have to make this work for the next few trips to St Anthony and Little Sahara.If I can make a recommendation for the shifter, I would ditch the one you have and go with a pro am unit. I tried adjusting the old one and could never get it right.
