Spring Tension Tie-Downs
I would think strapping something with suspension straps that already has suspension will allow some extra movement.
I believe it is just the opposite. The spring keeps tension on the straps when the load bounces a bit on its suspension.
Looks sketchy to me as well, but...
All the reviews on Amazon are 5 stars. There are only 60 some reviews, but that's pretty damn impressive nonetheless. 👍🏼
Anyone have much issue with loose straps? Since I’ve started using axle straps and spring clip ends, tied at the wheels, and not crossed, I haven’t had a strap come off. Sometimes they get a little loose, but I always stop at the same spot on my drive out to check straps, tires and wheel bearings.
500lb straps on weird shit? Yeah. Not on the buggy though.
Should be tied at the wheel to prevent the suspension from being much of a factor.
