J Alper
Site Sponsor
- Apr 30, 2021
- 2,069
- 1,798
LOL, Had a motor some had dynoed in CA, and it broke a piston, thought this would be a good one for peepsYou trying to burn down GD.com servers today? Minute 9+ will blow lids off...lol
If you go to Lake Speed Site, They talk about Low Speed Compression Breaking pistons on a lot of motors, This is just with Diesel Oil, but tuners that only tune for WOT, can have a effect on all Detonation, just a good thing to look out for. Octane and Oil can make a huge difference in what we do,I think he’s mainly talking about LSPI on direct injection motors there with the calcium.
Yeah, still has somewhere around 3-4x the ZDDP that regular oils have. Most of the ZDDP cuts are in the newer grades of gasoline oils.I thought Zinc was what made Diesel oil better, until the EPA said cut the zinc, so it's the same are regular motor oils now?
What's your choice these days Mr. Grease?The additive packages differ between the two oils. I am seeing more and more calcium in our diesel oil analysis results. Newer engines are built with tighter tolerances and more efficiency so I can only assume the calcium and molybdenum increases in the additive package is designed not just for soot but also for viscosity as a thickening agent.
I am no oil geek but have to analyze and convey a lot of the samples to my customers.
It's been quite the discussion given everything we work on is in salt water and water intrusion is a common occurrence. Following or trending oils and providing a good opinion isn't getting easier with the additive packages becoming more boutique even in the name brand oils.
Kendall GT1 20-50 is a great oil for turbo/supercharged gas engines.What's your choice these days Mr. Grease?![]()
Huh, actually pretty cheap/gallon...Kendall GT1 20-50 is a great oil for turbo/supercharged gas engines.
Hard to beat and easier to acquire Valvolene VR1 20-50
I didn't look at what Adam at Kali Kustoms gave me for my first oil change but I kept the bottle to reference later. Thats out in my trailer at Dunes Edge. Plan to sample the oil in the car when it gets home end of month.
Do you use that as a direct swap of 15W40? Or is that just for boosted motors?Kendall GT1 20-50 is a great oil for turbo/supercharged gas engines.
Things have changed in the gasoline and diesel oil blends. What was once ok to use has changed. 7.4 bbc won't care much but a new 6.2 in a truck won't like it.Do you use that as a direct swap of 15W40? Or is that just for boosted motors?
I recently started running my tired 7.4 Vortec with 15-40 Rotella, and now you guys got me second guessing.
