wesinls
- May 6, 2021
- 807
- 1,010
Trying to think about all the wiring I'll be doing on the car - and unlike the Holley system I have now, the trigger for the fans will come from two different sources (or so I think) - one from the factory Honda ECU from what I've been told is 205, and for the 2nd fan I plan to put one of those thermal ground switches on a radiator bung at say 180.
Issue is when you turn on ignition and go to start and having the fans running, not ideal...Some people have their fans on a switch - which scares me (if you forget and not paying attention).
I am thinking of using one of these time delay relays - say 10 seconds...given the car time to start, settle down a bit, and then fan(s) kick on....it looks like this relay can do both delays - i.e, have fans stay on for x amount of time once ignition is off, or delay x amount of time on after ignition.
