Esco
- May 4, 2021
- 15,758
- 8,461
Good seeing you in Glamis.Did you get the free Pro R belt? Or did Noel give it to somebody else?![]()
Sounds like you just needed a bigger test lightOnly a minor issue, but resulted in major pain until I figured it out: the wire I use to feed my switches broke in the connector near my fuse block. Would cause a random misfire when vibration shook the wire apart. Kept thinking it was spark related, so went through the entire ignition system (cam sensor, plugs, wires, coils, etc). Figured it out when I tested it yet again after the sun went down and the lights flickered in time with the misfire.![]()
LOL. It only happened under heavy load, and was breaking up, so the brain automatically went to ignition issue.Sounds like you just needed a bigger test light
