Mac
- May 3, 2021
- 946
- 2,192
Which ECU are you running? 450, 550, 600..I'm treading in somewhat new territory in building an engine harness. I am replacing the old Stinger ECU with a FuelTech system. Most of the harness build is self explanatory but things like my fan on my intercooler have me confused. When you turn the car to "ON", but not start, the fuel pump and the intercooler fan run for 5-6 seconds and then shutoff until started. The FuelTech has a fuel pump circuit set up so that is taken care of. I assume I need to set up another timed circuit for the intercooler fan. I know it needs a 40amp relay on it.
For the coolant fans on the radiator, I'm going to splice those together on one circuit. That is also already taken care of on the new ECU.
Any thoughts or experience on this?
What does your Output table look like?The FT550
Build the engine set up first, inputs/outputs, not necessarily the fuel/spark. It will lay the harness out for you. Takes a bunch of the thinking/planning out of it as it will configure it for you.Haven't built it yet. I was playing around with it but haven't done anything yet.
I'll be getting more serious in the next couple weeks and hopefully get a starting point so I can get the harness laid out.
