30 Amp Automatic Transfer Switch
RIDERED
What have you guys used for a 30 amp automatic transfer switch on your RV or Trailer?
I want to install one so I can run the onboard generator or my small Honda generator. I don't want to have to unplug one and plug it in to the other.
So what have you guys used and had good luck with?
You could make your own for under $50, if you wanted.  A simple open frame relay in an enclosure and some minor wiring.  I can help you in detail, if you're interested.  It's not hard at all.
Sure that would be great.
Here is an example of how to wire it.  If it doesn't make sense, hit me up and I will break down and explain.
This is from a panel we built for a specialized system for Vandenberg AFB, FYI.  Simple control relay for emergency power backup.
