Moparman
- 135
I have a Turbo R 2 and shopping for a paddle setup , I'm looking at the System 3 ss360 and the Tensor sand series in 32 inch , I'm a diner not a racer or hill shooter. Thanks in advance
33" Packard is rated for 250+ hp. Cant see that being a good match for a Turbo R.tensors or packard 33". the ss360 will work but your hill climbing while duning will suffer.
don't believe everything you read. Their paddles are short and will do just fine, with a clutch kit of course.33" Packard is rated for 250+ hp. Cant see that being a good match for a Turbo R.
Thanks for all the responses the Tensors looks like the way to go as I like to drift and slide and drive with the rear end alsoI asked the same question last year, you can look up my thread "budget sand tires" a little further down this forum. I ended up with tusks up front and strippers in the rear. It's ok overall but not quite as "playful" as I'd like in the rear, I'm going to play with pressures a little more this year. From what I rear, the 360s wouldn't work well for me as I drive with the rear in 2wd, but you may drive differently. I've heard good things about the tensors and kind of wish I'd gone that route, although I kind of remember them being out of stock at the time I was looking.
