ChasingSand
- 639
Just installed my double disc clutch and the car will not go into gear. I can almost get into reverse but it grinds if I get close. Pretty lost at this point.
Hey Jeff, the dual disc is an upgrade from the single disc. I didn’t do anything to the slave cylinder. Where should the adjustment on the cylinder be?Did you originally have a double disk clutch? Did you do anything to the slave cylinder? Did you makes sure the disks and spacer were installed on the correct direction?
I did. I bought the whole kit from Kennedy.Did you get a new flywheel for the dbl disc ? I don’t know if it possible to install a dbl disc int a single disc flywheel
So I adjusted it and can now get the car into gear. Shifter still needs adjustment but the car does move forward and backwards.How much free play do you have on the clutch arm?
It does not need much
Are you sure no air in the system?
My experience has been that different clutch packages will have different release/ engagement points. If your clutch is engaging in the last inch of pedal travel than it should also disengage relatively at the same point assuming that everything is assembled correctly. Bleed your system again making sure the bleed valve is pointing up. Do you have a stop on your clutch pedal? Good idea to have one if you do not. Slave and master cylinder seals and pistons are in good condition? Best advice I can give is to call KEP.So I adjusted it and can now get the car into gear. Shifter still needs adjustment but the car does move forward and backwards.
What is strange is it literally on grabs the last inch when releasing the clutch pedal. Is that normal?
Haven’t bled the system in 4 years but never had an issue before.My experience has been that different clutch packages will have different release/ engagement points. If your clutch is engaging in the last inch of pedal travel than it should also disengage relatively at the same point assuming that everything is assembled correctly. Bleed your system again making sure the bleed valve is pointing up. Do you have a stop on your clutch pedal? Good idea to have one if you do not. Slave and master cylinder seals and pistons are in good condition? Best advice I can give is to call KEP.
Looks like you found the issue by adjusting the slave.Hey Jeff, the dual disc is an upgrade from the single disc. I didn’t do anything to the slave cylinder. Where should the adjustment on the cylinder be?
The disc’s are installed correct per Kennedy’s instructions.
I am so relieved! Was dreading pulling the motor again!Looks like you found the issue by adjusting the slave.
