Kraut_n_Rice
Site Sponsor
- May 9, 2021
- 3,671
- 2,923
No need to cap them there. They need to be capped at the manifold.Where do these plug in to? Can they just be capped off?
Hmmm, can you show me a pic where they need to be capped at?No need to cap them there. They need to be capped at the manifold.
I don't have an example at the moment.Hmmm, can you show me a pic where they need to be capped at?
That's the return for the fuel. Should go back to the tank.
Here's a picture of those locations since I have easy access to this right now. I highlighted the two hoses in red. When I flipped the intake I needed longer vacuum hoses to reconnect these. Sounds like they could be capped also, but I hooked mine back up.Hmmm, can you show me a pic where they need to be capped at?
It may be a good time to do this as motor is boosted. Give a little more fine control.Okay y'all, what's the current recommendation for somebody looking to go from stock ECU to aftermarket/tune-able ECU?
Pulled my car apart to have the frame cleaned up and powder coated, now I'm debating whether to put back in the old harness and stock ECU or to upgrade.
Are you staying NA?Okay y'all, what's the current recommendation for somebody looking to go from stock ECU to aftermarket/tune-able ECU?
For now, yes. Hope to go turbo in a couple years perhaps?Are you staying NA?
Exactly this.Was thinking more about the follow up question. Does it make any sense to try an tune a stock NA motor? Probably not I'm guessing, but I remember reading about changing when the VTech crossover happens and thought that might be one advantage? There used to be a recommendation for aftermarket ECU somewhere in one of these Honda related threads but I couldn't seem to find it this time around. Possibly because of the sale to Holley?
I figured. So, is there any after market ECU that you'd recommend at this point? And, more importantly I guess, is there any point in having the ability to tune a stock NA motor? Should I wait for turbo upgrade?Exactly this.
There isn't anything that is PNP currently. I'm working on something to use Fueltech but I'm not quite there yet. Any NA gains would probably be marginal to the point of not noticeable.I figured. So, is there any after market ECU that you'd recommend at this point? And, more importantly I guess, is there any point in having the ability to tune a stock NA motor? Should I wait for turbo upgrade?
Plug n' Play.Thank you! Please excuse my ignorance; what does PNP mean?!?!? :classic_biggrin:
I have been using the same set for about 3 years and I feel like they have been removed and reinstalled about 10 times.Hola hola hola esteemed Honda gurus!
Can the intake manifold gaskets (I count three) be re-used or are they one time "smash and set" style that can only be used once?
I ask because after moving my flipped intake over to the new(ish) JDM motor I took it back off to run it through a sonic cleanser. Wondering if I should buy a new set of gaskets or not, even though the car was never run since the other brand new ones were installed.
Cheers,
-Mike
I saw 329 without intake, p/s. 360 withDoes anyone have a verified weight of a J35? I have found everything from 275 to 550 pounds on the internet.
