SandTrap
Moderator
- Apr 30, 2021
- 4,741
- 1,683
Well It's the weekend again what are everyones Plans? Hope Y'all have a great weekend
Working in the garage adapting a boat transom actuator to a KC lightbar.
If you connect it to a helmet sensor you can make it move based on where you look. That would be bitchen.Working in the garage adapting a boat transom actuator to a KC lightbar.
Not to mention a speed sensor, so it raises as you go faster....maybe a pivot as well for turning corners. You should be able to tie it into the Sensing shock systems so it knows when you are turning, going fast etc... like adaptive lights for cars.If you connect it to a helmet sensor you can make it move based on where you look. That would be bitchen.
Thank God for Insurance...Her Birthday weekend so her kids and grandkids are coming over for some food and pool time.
Just got my truck back from the body shop. $6K in damages from a blowout. Ford has a real nice way to fill the DEF fluid but if the tire catches the filler neck just right, it breaks chit. Not only did it tear it on the filler side it cracked the top of the tank at the tank side. They did a great job replacing the DEF tank, The Rear bumper and bed side of the truck, only problem is that just as I park, the check engine light comes on. So, I get to deal with that on Monday.
