FOG
- May 11, 2021
- 1,864
- 2,287
That really sucks.  Hope you get your money back and get the work done by someone else.
PM sent
I don't want to rain on any parades here, but using these brackets with the shifter you have will reverse the cable throw (push forward upshift/pull back downshift).Making some more progress, Its the little details. new misalignment spacers, cutting grip length bolts, new skid plates, trans cable brackets. Getting close to having it back on wheels and moving on to the body and interior panels.
Thank you for the post, I definitley want to pull the shifter down to go from 1-2-3-4-5 and push the shifter up to go from 5-4-3-2-1I don't want to rain on any parades here, but using these brackets with the shifter you have will reverse the cable throw (push forward upshift/pull back downshift).
This is backwards from how most people prefer (pull back upshift/push forward downshift), but it can be personal preference. It won't necessarily hurt anything as long as you know which way you are shifting.
It also adds drag to the cable having to make the 180º loop at the trans, which is not ideal for shift quality. It's best to bring the cable straight in from the back of the shifter into the front of the trans.
I'm only mentioning this as many are not aware of this. It looks like you could change this now before painting/powdering the chassis and having to change it later if you don't like it.
Curious why you are switching from the HP to the Dominator? My understanding is the only real difference is if you need more then 8 i/o's or multiple O2 sensors. I'm certainly no expert here, just going by what I found when I compared and selected the HP based on engine builder's recommendation.I have decided to get the Holley Dominator ECU, If anyone is looking for a Holley HP ECU thats only be used twice send me a message, its for Sale.
Holley HP does not support drive by wire. I want to eventually put in no lift shift and when i get the new whipple supercharger ill be running a throttle body thats around 132mm, Running a throttle body over 100mm with a cable is very hard at low speeds.Curious why you are switching from the HP to the Dominator? My understanding is the only real difference is if you need more then 8 i/o's or multiple O2 sensors. I'm certainly no expert here, just going by what I found when I compared and selected the HP based on engine builder's recommendation.
When i originally set out on this build I didn't think it would go this far, but of course one thing led to another and its looking like there will not be one thing left on this car from when I bought it. I had purchased the wrong clutch for the engine, but thanks to Sean at Weddle he got me sorted out quickly and sent me
the "WEDDLE 11" TWIN PLATE HIGH PERFORMANCE CLUTCH PACKAGE". Also did a new set of 934 CV's
Got the new fuel system set up, went with the Aeromitve pro series kit, and Injector Dynamics ID1300-XDS injectors. We also replaced all the fuel lines with black crimped BMRS lines and added a flex fuel sensor to run E85 if we choose too.
Got the batteries and kill switch mounted and installed. We are also replacing the battery cables.
Got the steering Rack rebuilt and new lines ran (don't mind the spray paint on the frame, its only temporary until we powder coat the frame)
Got Justin at SCU to make a shifter with the built in no lift shift package, and it is gorgeous.
Since the no lift shift requires Drive by wire, I purchased the Tilton pedal DBW linkage set and throttle sensor.
View attachment 125260View attachment 125261
Now for the best part......... We finally got the new Gen 6 3.8L Whipple Supercharger, and this thing is insane. We also had Wegner Automotive make us a custom larger (5") intercooler for the whipple.
View attachment 125263View attachment 125264
Stole these pictures of the custom intercooler from a friend of mine that did the same thing with his LS7, but you get the point.
View attachment 125270View attachment 125271
We are pairing this with a massive 130mm DBW throttle body and Holley harness to control it. This thing is gonna be an absolute monster and if everything goes well we are headed to Dyno next Friday.
I was the most annoying person in the world for whipple and wegner automotive for the last 8 months, I am surprised they didn't block my numberWow - you actually have one of the new 3.8 blowers from Whipple. I thought they were just unicorns and didn’t really exist.
