John@Outfront
Forum Moderator
- Apr 30, 2021
- 1,722
- 2,590
Hello Guys, im a little out of my comfort zone but this customer wants me to do a lot of things to his car. One of those is that he has a Fab9 rearend with leaf springs, they mounted the shocks inboard of the leaf springs but in doing so welded in a bar above the diff housing to mount the shock tops, needless to say the diff hits this bar and the exhaust position was compromised lower because of the same bar resulting the exhaust hitting the diff too. he has an unlimited budget. simply my suggestion was to cut the cross bar out giving more clearance for exhaust and diff, and make my own upper shock mounts from inside the trunk area. maybe a 8-10 hour job. once i mentioned that he said that "everybody" is going with a four link kit and he wants the ride quality to be the best it can be.
So i have no idea if that is true or not. is a four link far superior or can a leaf spring set up work just as well? dont want to go down one rabbit hole to find out the other rabbit hole is a better option when finished
will post more pics of the issues once car is back on the lift
