SANDBAM
- May 6, 2021
- 253
- 182
Where is the compressor mountedI did no tank just straight from compressor to control its fine for adjusting the bags and i don’t lower the care to look cool
Is great car ! - glad you’ve got it stillBehind driver seat same place it was when you owned the car
Never really thought about the heat. But I turn mine on and off with each use. If I get the adjustable ride height set up I'll figure out something for a heat shield.I have a similar setup I installed. I highly recommend to put some heat shield between your seat and the compressor, they get hot!
Meh..... free seat heater.... LOLNever really thought about the heat. But I turn mine on and off with each use. If I get the adjustable ride height set up I'll figure out something for a heat shield.
I lower the car to get my old ass out. and to look coolI did no tank just straight from compressor to control its fine for adjusting the bags and i don’t lower the care to look cool
Looks greatBTW- what transaxle do you have?
