J Alper
Site Sponsor
- Apr 30, 2021
- 2,020
- 1,755
I just got done with mine spent a lot of timing planning it out, I am only on 3/4 of a acre so i wanted to match the house, if it is far enough away the esthetics might not matter as much, I framed mine with close friends @sandroosten was the contractor for Southern NV, and he was the master mind, I did the electrical with help from a Board member, that was actually really fun, and @sandroosten framed the interior room and stairs, and hung all the trusses,
My big take away and difference from a close friend that just did a steel building is,
1. Mine matches the house to a T, I feel what i spent i will get double out of the shop, it looks like it was build at the same time,
2. The close friend that built a steel structure spend 30% less but, not sure what value it might add or subtract, it is harder to place value on a steel building,
3. depending on what kind of work you are doing, i like a lot of wall space, for me i 2700 square foot garage with 2 doors one 12 foot wide and one 14 foot, the last garage i placed benches in from of the doors, so i just wanted a lot of wall space due to the larger tools like the CNC machine and welding tables,
4. Best parts from @sandroosten was the 17 foot walls, 16.5 plus a steam wall, this allows for a true 2nd story loft with stairs, i store all kind of stuff up there, mainly because of the stairs John built is easy to go up and down, no ladders, just plain easy to walk up stairs.
5. Steam wall is nice i can wash the floors and it does not eat the drywall,
6. Background is concrete, so i geek out a little on that, If you have rebar and control joints, unless the rebar is cut in the same place as the joint, you did not accomplish Crap, for what you pay to saw joint and saw bar, go technical on the crete, i use a Shrinkage Reducing Admix, this will reduce cracking by 50-75%, I poured a 6'' slab with rebar and ZERO joints, this is so nice to have NO dust in joints on the floor, and NO issues with heavy as equipment rolling the edge of the sawed joint, and NO curling over time at the Joints,
7. Best money spent was Westech Hi Mass UFO lighting, if you do commercial UFO lighting make sure to wire it for a dimmer, my shop is brighter inside than outside, so welding with hi reflection in the back of the hood can be irritating,
8. I wish i had wired it for AC, outside temp was 120 and with heavy insulation the inside was 98 degrees, if i wired it for AC, most likely would be installing it right now,
