Mac
- May 3, 2021
- 777
- 1,649
Sorry, usually things are welded to the chassis side and bolt goes up into the tab to create a smooth floor. Didn't look at your pic, but reversing the fasteners would be worth the time since your current setup makes thread damage easy. With nuts/bolts, no big deal, break that focker off. With rivnuts, tears will ensue.Thanks of the inputs.
Not sure I want to tack probably 100 plus of these things. Plus, I don't have an aluminum welder.
Get a Fumoto, Amazon.com: Fumoto F-133: STANDARD VALVE WITH 12MM-1.25 THREADS WITH LEVER CLIP Gold : AutomotiveMy car has a full belly pan, and after taking that thing off once, I put nut certs or rivnuts in every tab. It has been that way a few years now, no issues. my bolts are 5/16" and the come up from the bottom. I didnt notice any addtional noise or rattle from the minor thickness they added.
I also did the rear skid plate, its on and off every trip for changing oil. those are 3/8' bolts and I did mess up one of the nut certs at some point, I just drilled it out and put in a new one.
Im not in love with the look of the nut cert compared to just seeing a bolt head... but it is way easier to work on!
I put one of these in mine. It does take more time to drain than when I just pulled my skid plate off. But I found my old pump from my boat days. That sucks the oil out much faster.Get a Fumoto, Amazon.com: Fumoto F-133: STANDARD VALVE WITH 12MM-1.25 THREADS WITH LEVER CLIP Gold : Automotive
You won't have to drop your skid plate for oil changes. It works great!
