Funco sequential shifter
Jtmoney714
Anyone have any pics of their funco shifter  for a mendeola on the bench? I want to see what it looks like and possibly buy one.
They are awesome shifters. I put several pics over in the S4 sequential thread
Does it just come with the arm or does it come it a mounting bracket too?
If I remember correctly it was the bracket, both levers, and the cables. Does not come with the turning brake but you can mount regular turning brake on it.
It basically a piece of aluminum with a bolt through it, not much to them,
If you are after just the funco handle, Grant, but we have aluminum handles with bearings in them, if you need one,
Sent you a message.
Sent you a message.
Just sent it back,  Yes we will just sell the handles, actually way easier,  Ours has two bearings with 8mm holes, bearings around 1.5'' apart for stable feel, just add a thick tab and a bolt, or two tabs one on each side of the bearing and get the best feel,  tops are blank so we can tap it for most sizes,  we tap the top for a 7/16, this is the same as a mustang so any mustang handle will work,  in the past we use the Albins Knob, or have use the billet J mar handle, or make one on the lathe in the shop,
We are pretty easy going,
