Mac
- May 3, 2021
- 790
- 1,736
Will you be dry camping without a trailer?We definitely want it on the RV as we won't be just using this in Glamis and definitely not always have the trailer.
I have thought about adding water and such to my enclosed at a later date.
We have a macerator on the RV black tank. Other than needing a lot of water to flush it, I LOVE it. It makes dumping and cleaning the black tank so much easier.
My in-laws had a trailer that had 2 grey tanks on it because the logistics didn't work (front bath, rear-ish kitchen). Each had its own dump valve that connected to the main 3" dump. venting is done through the fixture plumbing anyway.I have the room to put an extra tank in, but yes, the plumbing has me thinking a bit. "HOW" do you pipe it in to fill, vent and transfer as if it was "stock"? I can figure it out, I was just hoping for some easy answers.
Or hook the extra tank to the city water connection with a short hose and just use the pump for the aux tank to provide pressure.If you have the room for an extra tank, the easiest would be to just plump it to another pump and pump that into your existing water fill. Trying to make it all work together could be challenging. A simple pump and a hose and you would be good to go. Just like transferring from a trailer, but the motorhome carries the tank.
